The_Works
Aug 31, 2016Explorer
Diesel Fuel
We started a 6 month work kamper job Mount Pleasant South Carolina. My question is, should I fill the 100 gallon fuel tank in our motorhome, half fill the tank or leave it as it is with 1/4 of fuel in...
MudChucker wrote:The "deicing" additives in what could be called "winter formula" are the same additives that keep moisture out of your fuel tank, put it in suspension in the fuel, and allow all of it to go through your fuel system safely and out your tail pipe.JimBollman wrote:The Works wrote:
He is going to be in SC, he doesn't need Winter treatment.
You are correct 'ish...
Winter additives are usually better at dealing with condensation and water in the tank.
