12ItSu30a's avatar
12ItSu30a
Diesel pusher engine size
I am looking to upgrade from a gaser to a diesel pusher. The new RV is on the Freightliner XCS chassis using a 340-hp Cummins ISB 6.7L turbo-charged engine. It has an Allison 6-speed autmatic 2100MH transmission. The RV length is 35' 6" with a GCWR of 30,000 lbs and a GVWR of 26,000 lbs. I pull a car on a tow dolly which falls into the spec of the trailer hitch 5,000-lbs drawbar/500-lb.
My question; is the 340-hp diesel engine an adequate size engine? I have only had gas engine motorhomes.
Thanks for your feedback,
Ron
  • Rule of thumb is 1Hp per 100 lbs,so going by that a 340hp motor is good for 34000 lbs GCWR.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
