path1's avatar
path1
Diesel temp storage in motorhome gas tank?
I need to drain my 01 diesel pick up fuel tank, and fix the fuel line, about 20 gallons of diesel. Parked beside my diesel pick up is my 03 gas powered motorhome, and its gas tank is sitting close to empty.
I'm thinking about transferring the diesel from my diesel pick up to gas motorhome. After fixing the diesel fuel line, I'll transfer diesel back.
I'm sure there will be some residual diesel left in the gas motorhome that will make its way thru the gas fuel system. I'll add 5 gallon of gas then fill up to dilute any diesel left.
If the gas motorhome runs rough, I'll drain out of valve on fuel line and add gas. Until its running smooth and nothing but gas makes it thru the gas line. And maybe do a gas filter change.
What do you think? Will it work or not?
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Feb 12, 2026
