azdryheat's avatar
azdryheat
Diesel won't start with low air. Entegra MH
Never seen this before. Brand new Entegra Insignia, with keyless ignition and Spartan chassis, disables the engine start sequence if the air pressure is low.
We were trying unsuccessfully today to get the rig going so we could take it back to our store after a four day RV show. The ring around the Push to Start button is usually green and the Cummins starts right up. Today it was a yellow ring with a low air pressure warning on the dash readout. None of us drivers are familiar with this keyless system as our store doesn't stock Entegra pushers.
Our mechanic came to the scene and was also baffled. After searching the owners manual he found there is an override switch located beneath the dash to the left of the steering column. Pushing the switch allows the engine to start with low air pressure.
We all thought what a ridiculous idea this was to inhibit starting due to low air. We don't know if this is an Entegra or Spartan idea.
So, if you find yourself with low air pressure and the engine won't start, push the override switch.
  • rwgeiser wrote:
    Does it have an air starter?
    I hope not. But they were fun to scare to **** out of the unexpected passer by!
  • Does seem a tad odd....as noted, you can't build air unless the engine starts unless it has some Aux compressor for such purposes??
  • How else would you build air? That seems a strange way of doing things.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
