road-runner
Aug 27, 2016Explorer III
In a single-phase induction motor, the phase-shifting property of the start capacitor is used to create a rotating magnetic field to get the motor turning from a dead stop. Once the motor is turning it is not needed and in most motors is disconnected. The run capacitor counteracts the inductive phase shift caused by the stator winding(s), providing power factor correction. The motor will run without it, running hotter and using more power.
If the motor never starts turning, the start capacitor would be the suspect. Of course, it's impossible to see this inside the compressor, and it could be a problem other than one of the capacitors, as suggested in the first response. Could even be a locked-up compressor.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
