SCClockDr
Aug 28, 2016Explorer
John&Joey wrote:
So does one need to discharge that capacitor after unplugging?
Generally no as this application involves 120VAC vs 1Kv+ DC which can really kick.
The proper sequence if you want to be sure.
- Disconnect power
- Use an insulated screwdriver to short the capacitor's terminals
- Remove the capacitor from the unit.
If the terminals are insulated (some form of plug etc.) you are good to go without shorting.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
