robsouth
Nov 09, 2013Explorer II
Generally, batteries in parallel should be the same type, size and age as an older, weaker, smaller battery will draw down a newer, stronger, larger battery to "equalize" the charge so you will not be getting the benefit of the newer battery. Best bet is to replace both at the same time with like batteries.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
