otrfun
Oct 20, 2014Explorer II
Alpenliter wrote:I like your idea, Alpenliter. I assume you'd need a good flat surface to do that. What size valve did you use? 3"? What did you use to mount the gate valve to the tank besides the gasket?
I drilled a hole in the side of my 28 gallon Barker and installed a rubber gasket and a slide valve. The macerator pump fills it up in the back of my truck, then I go to the dump site, attach the sewer hose, and pull the handle. Has worked for me for four years now.
