klutchdust's avatar
klutchdust
Explorer II
Jul 30, 2017
Dimensions inverter reset after battery drain
Coach batteries died because I failed to start generator and recharge them after using inverter at night. Now the batteries are recharged but the inverter doesn't allow power to the TV. The green light is on, I can hear a clicking when i move the switch. Now the circuit breaker . I pushed it to the off position to test it but pushing the ON side It won't reset. I pushed a number of times. If the breaker failed is it replaceable or is it permanently to the inverter. I have to remove drawers and wood shelves to get to the inverter next to the kitchen sink. Im on the road now.
  • Update: Now i remember after this happened once before. The reset button on the inverter, I guess it's the breaker, only likes to be pushed from the very edge. When I pushed the breaker in, nothing. When I pushed the breaker in so the button goes in at an angle then it resets. This isn't acceptable to me and once home again will look into it further. This inverter came with the coach and is built into the cabinet.It has a Levity breaker on it and other than the on off switch that's all that is visible.
  • Not knowing what inverter you have makes any suggestions wild guesswork. But my first thought would be to disconnect your coach battery again, turn off the inverter, wait at least 30 seconds and then reconnect the battery and then turn the inverter back on.
    See if there is some automatic reset in the inverters system.
    Good luck
  • Sonoma. Near Santa Rosa. Orange. Near Anaheim, LA Area.
    Can you post images of the control panel and provide a clue as to the Inverter model?
