ViaSteve2015
Jan 02, 2019Explorer II
Tom_M wrote:
I assume that there is a switch on the light. You could mount a dimmer next to the light such as this one available at Home Depot:
https://www.homedepot.com/p/Armacost-Lighting-2-in-1-White-LED-Dimmer-DIM2IN1-96W12V/203227246
There's also a wireless remote available:
https://www.homedepot.com/p/Armacost-Lighting-Wireless-Touchpad-for-2-in-1-LED-Dimmer-DIM14REM/205884027?MERCH=REC-_-PIPHorizontal2_rr-_-203227246-_-205884027-_-N
But, you have to make sure the LED bulbs in the lights are dimmer compatible.
I'd try changing the bulbs first and seeing if you can get the amount of light you want. If replacing the bulbs, make sure to consider whether you want bright "daylight" bulbs or warm light bulbs.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
