Matt_Colie
Jan 02, 2019Explorer II
mtofell1 wrote:
Does anyone have an easy solution for the light over the bed in my 5th wheel being as bright as search light? The things I find online for dimmers look like switch replacements but the light in question isn't on a switch. I found some Youtube videos but bailed when I see people tearing apart the cabinets and pulling wires. I'd even be happy with a somewhat opaque cover or just anything to make this thing usable. My trailer is a 2016 and I believe the lights are LED.
OK Mtofell1,
If it is a 16 build, it may well be a LED fixture, as such, you won't be able to buy a dimmer at Lowes Despot. 12V LED dimmers are available, but you say that the light is not on a switch, by this I think you mean a wall mounted switch?
Are we good on that?
It does have a switch that is a pull sting for the switch - OK?
Now, you have a number for the bulb (if it has a replaceable "bulb"). You can look for a lower output version as mentioned. That may not be possible.
Another very real shot that will not require tearing things up much at all would be to replace the pull single setting switch with a multi-step switch. That you can procure at any big box. If the fixture has multiple elements, you can set up to use less than all of them.
Or, if it has a single LED set, you can use that switch to run it through either some diodes or resistors to reduce the power to the LEDs. This is a very do-able option, and neither will be expensive.
Good Luck,
Matt
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
