Tom_M1
Jan 02, 2019Explorer
The Armacost dimmer I mentioned is 12 volt. If the LEDs in the fixture do not have a voltage regulator, the dimmer should work. Both the dimmer and remote can be surface mounted. The remote is battery operated and needs no wiring. If the fixture can not be dimmed, Home Depot sells Armacost 12 volt lights that can be dimmed. If it doesn't work, return it to Home Depot.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
