dougrainer
Feb 27, 2018Nomad
A LOT of so called 12 volt dimmer switches will NOT work with RV 12 volt LED lights. They either will NOT work at all or they will cause the LED to pulsate. The usual factor I see, is the COST is what determines what will work correctly. Remember, RV LED lights are the cheapest than can be made and installed. I would make sure that any switch you find can be returned if it does not work. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
