tommymsw
Feb 27, 2018Explorer
Gdetrailer wrote:tommymsw wrote:
So I have LITTLE chance of running a new wire. I have a class A Winnebago and all the wires I see seem to have been run in the walls and then had foam sprayed into the walls. It is REALLY nice for sound and insulation, but not so nice for running new wires!
The LED light I put in are "strip lights". They work GREAT and are dimmable. But looks like I am stuck just using them normal. It is a bummer that they don't have anything with a few (resistors?) in them to lower the voltage. Even if there were just a few levels... Like 3v, 6v, 9v, 12v.
Can you mount the dimmers in the light fixtures?
Might be a bit inconvenient to do so but this way you can dim then when full brightness is not needed and turn them up to daylight levels when needed..
Leave regular switch in place and it will turn the light on/off.
Otherwise if you wanted to dim slightly it is possible to add a resistor in series but you will need to know how much voltage the resistor will drop and how much current will be flowing through the resistor to make sure you use a resistor wattage high enough for the heat dissipated..
If you do the resistor route, don't tell, the anti resistor police on the forum will be whining about all the energy you are wasting and will beat you over the head about it until you change your mind :E
I came here now because I had that EXACT thought. The lights themselves DO have a hot and a ground!
So MAYBE the ground wire runs near where the switch is and I can grab it there (I will have to look at the wiring documentation).
Otherwise... It think you are correct... I should be able to put a dimmer ON the light (or right next to it) although that will be a little weird? I think it will look OK. The dimmer I have is just a small, dark brown box that you touch to dim. Shouldn't look that bad on the ceiling.
Not ideal? But workable. :)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
