tommymsw
Feb 27, 2018Explorer
I GOT IT TO WORK!
I just used the power in and out to the 2 wires that were at the switch. Then I just tied BOTH grounds to a ground wire running near the switch. Seems to work fine so far! I will check it for heat and such although the LED strip is pulling so little power, I am not overly concerned.
Thank you for all who helped. I would have given ip and returned it without the help.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
