Dirtdaddy
Jul 18, 2023Explorer
Flapper wrote:
It's an attempt to prevent a stronger battery from charging a weaker battery. Sometimes used when the batteries are of two different capacities, or wide age difference.
Best to always have both batteries be the same type and age. Then one doesn't need a "patch", they keep each other in balance. Your diagram doesn't show, but depending on where the load comes off, or the charger connects, there could be issues with getting full use, or full charge, out of one or the other. Get two matching batteries, and get rid of the diodes.
I put two matching batteries in it, so I was hoping I could replace this config with a solid 4 AWG on both the positive & negative terminals. When I dug into it I noticed this circuit and wasn't sure what it did. Thanks for the explanation!
