wa8yxm
Jul 19, 2023Explorer III
Dirtdaddy wrote:
I think "Flapper's" response make the most sense. I think this was an attempt to balance the batteries when one was weaker and/or older and not well matched. I'm going to remove the diode circuit this weekend and replace with large AWG wire between the negative terminals.
That would be my suggestion too.
Also there are a lot of "Myths" about batteries in parallel Some of them are based on batteries in series.
now when you take a pair of GC-2 and put 'em in series to make a big 12 volt they need to be twins. Same everything (Make, Model Age and so on)
But when you put a pair of 12's in parallel.. That' not the case.. The myth is if you put say a Group 24 next to a Group 31 the 24 will "Charge faster" and convince the charger that it's full so it goes to float before the 31 is full.. NOT SO.. or that the 24 will run down faster.. again not so.
What will happen.. For reference I'm going to use 70 AH for the 24 and 130 for the 31 for 200 AH total
The smaller battery will take 35% of the charging current and the larger 65%.. They will hit full in perfect lock step (After the first discharge recharge cycle)
And likewise when discharging they will share 35/65 and hit the cut off point precisely together..> The perfect power commune.
Now in the case of older batteries that have developed a higher internal resistance.. Well then you may have something but they will work it out just not always in perfect lock step.
I am the voice of experience on this.
