- Bill_SatelliteExplorer IIIf there is an available code you can simply use the instructions for using the remote to find the code. If there is no 4 digit number for you brand then you just the alternate instructions and just click through the codes 1 by 1. When the TV powers off during that routine you have likely found the code that will control the TV.
- I have had to go to Direct TV and look up correct codes for make and model.
Code look up - SCVJeffExplorerHave you looked in the programming book?
There are also websites dedicated to gathering remote codes for all kinds of way off brand electronics.
http://moxi.com/us/support/MC4R/MoxiHDDVR_remotecodes.pdf
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
