Kountryguy's avatar
Kountryguy
Direct Charge Circuit
I would like to run a direct line from my truck alternator to the house batteries in my fifth wheel trailer. Has anyone done this project that could offer some suggestions on how to and what materials used? Any help will be appreciated.
  • There is one, but I want to increase the charging capability. I want to bypass the 7 pin connector. I will have to run new wires in the trailer also.
  • There should be one already that goes from your alt to the TV battery and then to the trailer battery through the 7 pin plug.
  • A 12V 40A "Bosch" style relay, a bunch of heavy ga wire and most important.. A BIG FUSE within 18" of the truck battery.
    So, you have truck battery, then fuse, then fuse connects to the common terminal of the relay, the normally open (N.O.) terminal of the relay connects to your heavy ga wire which then goes to the trailer charging connection on the truck 7 pin connector.
    One side of the relay coil is grounded and the other side of the coil goes to a KEY ON switched power (you will need to hunt this down since it is difficult to say where you will find that now days).
    Wire ga size, well 8ga might be a good place to start..
    Fuse size, size no larger than allowable current of the wire size or the lightest part (like the 7 pin connector).
    10 ga wire 30A max fuse
    8 ga wire 40A max fuse.
    Any larger wire and I would say you are going to melt the 7 pin connector if you fuse larger than 40A..
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 17, 2025
