lenr's avatar
lenr
Explorer III
Jul 18, 2015
Dirty power stops fridge from working
My son's 2008 Norcold N611 refrigerator has been acting up for years. It would just quit cooling with no warning and the light inside would quit working. We blamed it on out of level some times but that didn't cover every situation. I came across a thread somewhere (can't find it now) that was suspicious of dirty 12 volt power causing refrigerator problems. So, we shut off the Parallax converter and everything started working properly including the light. We replaced the converter with a Progressive Dynamics and there has been no fridge problems since. I am amazed that Norcold has a design that is that sensitive to dirty 12 v power--technically, with a battery connected it should be providing a lot of absorption of any dirty power spikes.
  • lenr's avatar
    lenr
    Explorer III
    We choose PDI on purpose for their reputation, but only replaced the converter section, so the 120 v section remains the same. Yes, the fridge is almost directly above the converter while the battery is 20 ft. away. The craziest thing was that the inside fridge illuminating light would not work when the Parallax converter was on but worked just fine otherwise. The control lamp did flash error codes at us when the Parallax was on, so we almost changed out the Norcold control board. Figured that the Parallax would go eventually, and that replacing with PDI was a good investment in the future. Remain disappointed in Norcold for a design that sensitive.
  • Items that require clean 12V DC (circuit boards and such) do NOT function very well on 'dirty 12V DC'.........AC ripple above .6v is dirty
    A good charged battery supplies nothing but clean DC
    When you plug into AC power.....converter is supplying the DC System even when battery is fully charged.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Ron3rd wrote:
    Parallax has a reputation for being the biggest piece of junk ever put in a trailer, but mine worked fine for 10 years in my old trailer. Good that you found the problem.
    Not quite but they purchased Magnetek which did.. I would give Parallex a high position on that chart though.
    To the O/P.
    A lot depends on how things are connected, The common Parallex 7300 is a combination device, 120vac Power center, 12 VDC power center and converter all in one box. This means the converter is INCHES from the distribution panel, where as the batteries can easily be 1.5 times the length of your RV (Depending on where everything is) So the batteries have a lot of wire between them and the converrter where as the fridge has only a few inches (from the fuse that feeds it)
    I have a progressive Dynamics 9180 with wizard.. the filtering on that is nice.. I have some very sensitive hardware that can not tell if the batteries are connected or not,, works the same either way.
    But then you know the PDI units are well built now don't you :) (Since you installed one.. Oh by the way, Good choice)
    In 2005 when this house was new I did some serious research looking for a better converter than the one I have,,, This also applies to all the PDI units with wizard either built in or plugged in.
    I failed to find a better one.. Total and absolute fail. Found some that are as good, but not one better.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
