dougrainer
Aug 07, 2023Nomad
1. Boondocking usually means NO 120 to RV
2. So, since the roof AC/HP is 120 ONLY, you have no problem
3. Can you post pic of wall tstat? I have NEVER seen nor heard of your type problem. ALL RV HP, the furnace can be utilized without worrying about the HP coming on, including Dometic. INCLUDING if it is a HEAT Strip instead of a HP. The Heat Strip is also 120 volt.
4. IF NO PIC, can you supply P/N of wall tstat?
5. I think you have a lack of knowledge on your system. Do you have any manuals for your System? Doug(44 years as an RV TECH)
Is this your tstat? Does it have 3 wires going to it?
https://www.etrailer.com/Accessories-and-Parts/Dometic/DMC79FR.html?feed=npn&utm_source=google&utm_medium=cpc&utm_campaign=Google%20%7C%20Shop%20-%20Accessories%20and%20Parts&adgroupid=86797745500&campaignid=1672411894&creative=404001588944&device=c&devicemodel=&feeditemid=&keyword=&loc_interest_ms=&loc_physical_ms=9027230&matchtype=&network=g&placement=&position=&gclid=EAIaIQobChMI8vb_vOnKgAMVBkl_AB0a1wZ8EAQYASABEgKDZfD_BwE
