ol_Bombero-JC
Jul 14, 2018Explorer
bob213 wrote:
The one campground where i would use the macerator the most is set up for MH's. When I back in all my hookups are on the wrong side and my sewer hookup is at least 30 ft. from my outlet. I don't want to carry 50' of hose but due to circumstances I really don't have a choice. This is usually a 14 day stay and 10 hours away from home so we are loaded and storage becomes an issue. I guess I could always make the room to save some $$$. Thanks. I'll take a look at the one 2oldman posted.
A "normal" rubber 3/4 hose won't take up that much more room than the
"flat" type - and can be found almost anywhere.
You cold always shorten a 50' to 30' to save space - at the cost of a coupling (or two - the 2nd for the 20' that you're using at home, or?)
"wa8yxm" - the "Goodyear" brand of 3/4" hose I have is RED. Hope that meets the color standards, ROTFL.
"JohnG3" - the "COUPLE HUNDRED FEET" poster......guess you probably also burn up a few 16 gauge extension cords when you're supplying your electrical needs from a 20 amp outlet at the same distance, huh!?
