aruba5er
Oct 23, 2013Explorer
My neighbor has contantly had a dead battery. it is stored off site and no power. I showed him the load on the battery because he does not shut off his weingard antenna and you can not shut off the propane detector. .97 amps. I guess I finally convinced him to disconnect the neg battery lead. I also have a friend with a big pusher and the electric relay battery disconnect does not disconnect everything like the propane detector, the steps that come out when the door is opened. the inverter seems to be on standby and what else. His batterys are always dead and what a deal to find the wires to disconnect. Maybe going to get a Quest disconnet and shut off everything
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
