Sandia_Man
Jul 12, 2019Explorer II
On our onboard genny there were a couple of instances where my DW had turned off the genny while under heavy load, as well as started the Onan with a heavy load. Thankfully all was well after those episodes, I subsequently explained the reasoning why those actions can cause damage, although for the most part we always have some nominal load when turning the genny off or on.
After a decade of dutiful service from our Onan, which was overkill most of the time anyways, we decided to purchase a portable inverter genny that could run our RV AC unit while being fuel efficient and less noisy. We picked up a Champion inverter genny with remote start. When using the remote loads do not need to be removed, loads do need to be removed for electric or pull cord start up.
