craig7h
Jun 30, 2021Nomad II
I had a simular problem this year. It ended up being the solenoid valve was causing the problem. Find the solenoid valve and make sure you are getting power both to it and through it. If you have power to the valve but not through then the valve is not opening thus its bad and need to be replaced.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
