BFL13
Jun 05, 2018Explorer II
Since it is hard to find solid info on which controllers will fry, it is best to assume the worst and have a way to disconnect the panels before you disconnect the batts from the controller.
Also, separate from that, many controllers are 12/24 and you need to connect to the batts first so the controller can see if it is 12 or 24 before you connect the panels.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
