pianotuna
Jun 08, 2018Nomad III
Hi,
You need to be able to disconnect the panels first, so the wire may not be a good plan.
The breaker between the controller and the battery bank should be extremely close to the battery bank end of the wire.
Spridle wrote:
for my small (3)100 watts solar panels i used this for disconnects breakers and fuses:
http://www.midnitesolar.com/productPhoto.php?product_ID=79&productCatName=BOX%20ENCLOSURES&productCat_ID=10&sortOrder=1&act=p
I used one 20 amp breaker to disconnect the solar panels to the charge controller and one 30 amp breaker to disconnect the charge controller feeding the battery's. use bushings in the holes of the box. I tied the breaker handles together with a piece of tie wire so they both disconnect at the same time.
http://www.midnitesolar.com/productPhoto.php?product_ID=184&productCatName=Breakers&productCat_ID=16&sortOrder=6&act=p
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
