RoyB
Mar 15, 2016Explorer II
That is what I would do or at least keep checking the battery for fluid boiling out.
Of course the best you can do is replace your older converter/charger with a SMART MODE charger like the PD-9200 series is. Then you won't have to worry about the battery anymore... You most likely will only have to replace the charger module and hopefully can keep your same 120VAC and 12VDC Distribution Panel. Just replace the module in the bottom compartment.
Call Randy at BESTCONVERTERS...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
