Sam_Spade
Mar 16, 2016Explorer
Chandalen wrote:
You should always leave the battery connected when your using the camper / plugged in.
Well always covers a LOT of ground.....so that is not right.
IF the time period is really long, as in 6 months or more, AND your converter doesn't drop to a real float voltage....then you should not leave the camper connected OR the battery either.
And automotive equipment is supposed to be designed to withstand 16.0 volts at the upper end.
Aside from those two things, you make a good point. :B
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
