pianotuna
Apr 06, 2016Nomad III
If you have a modern 3 stage converter by all means do keep it plugged in.
However 13.5 volts is a bit on the high side--so I'd consider doing 24 hours on and 24 hours off.
A better solution may be to monitor the battery voltage and turn it on if it gets below 12.6.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
