wa8yxm
Sep 07, 2013Explorer III
If you visit an RV store there are some realy heavy duty Switches,, Marine grade battery disconnect switches that can easily pass several hundred amps when closed... I'd put one of these in one of the battery leads (Does not matter which so long as only the battery is connected to one side and whatever is hooked to the battery now is connected to the other side).
That way you need no wrench.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
