dougrainer wrote:
Can you give year model of RV? There is not a legitimate supplier out there that I can find. The part seems to be an orphan part and not supported by Dometic or built. As others have said, Dinosaur is your best bet. Doug
Dometic went to hell in a handbasket over the course of the last 10 years or so. They used to be great, they made great products and SUPPORTED them. Not no more, in fact not for a long time.
They made a fridge which they pushed to a lot of builders starting @ 2015, Model DMR702. Actually they had it made in China, then slapped their name on it. That fridge was put in 10's of 1000's of units made by Rockwood/Flagstaff and some others from 2015 until at least 2020, maybe longer. It was a piece of junk. A defroster heater to keep frost from building up on the cabinet face between the Fridge and Freezer would overheat, and melt the cabinet. When the fridge was shut down, if any ice in the freezer melted the water could make its way into where the eyebrow board is located and would destroy the eyebrow board. Dometic stopped making, or having those eyebrow boards made, long ago. The handles would break almost just by looking at them. Garbage, not unlike their AC units which are also junk, and every other thing they're associated with.
