MEXICOWANDERER's avatar
Sep 09, 2018
Discrete Large Lithium Battery Control
This gets a bit involved so grab a cup of coffee.
There are dime size discs that have been around for decades that shut off AC power when a certain temperature has been reached. Most are guaranteed for 30,000 cycles minimum. 30 amp capacity. One per cell Meanwell makes a huge variety of adjustable FIVE VOLT power supplies that can be adjusted to exact tolerance for lithium batteries -- from 5 amps to 150 amps depending on the model. One per cell. The low voltage cutout can be installed on the pack load output::A high quality low voltage disconnect can be paired with a 200 or even a 500 amp relay.
What kind of low voltage disconnect does the Tesla use? It would be nice if the relay used milliamps not full amps when energized.
The temperature cut outs are connected in series.
By correctly selecting the power supply capacity it limits the per cell amperage automatically.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
