camperkilgore's avatar
Apr 21, 2017
Disk Brake Conversion
Just a post to let folks know about my Disk Brakes. I had Performance Braking put this conversion on our 2005 Cougar Fifth Wheel, and a guy named Dennis came to my house and did the install. I'm very happy with the system so far. One thing I will mention, and it's the reason for this post in case someone else runs into the problem.
My tow vehicle is a 2003 Dodge Ram 2500 with a Prodigy P3 controller, and after the install I had intermittent NC errors(not connected) on the controller. This freaked me out a little even though the brakes seemed to be working as they should. After extensive checking on the truck end, I could not find a connection problem. I spoke with Ron the owner of the company, and he knew what the problem was. The brake pump needed a resistor across the blue wire and the ground wire. It fixed the problem. The controller now indicates properly.
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 02, 2025
