evy
May 21, 2015Explorer
jrnymn7 wrote:
Venting from the side wall would work fine... mine does, and so do hundreds of thousands of other rv's. And you could, theoretically, end up drawing trapped exhaust pipe heated air up thru the cabinet.
But yes, the fuel filler is a logistics/safety issue, for sure. Any way you can install the fridge away from that area?
Believe me if there was a way to simply put vents I would've gone that rout, but I have so little space (Ford extended E250) There's not a lot of options...
Here's a look at my floor plan design, it has not been updated in a while, since I bought the van I have realized that there are many issues/conflict that I have to re-think, for example : the furnace and water heater, and I will switch the refrigerator's position with the bathroom (behind the driver's seat) because of a beam I can't cut in the outside wall...
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
