Old-Biscuit
May 21, 2015Explorer III
Do you have the fridge installation manual for your model?
Follow the 'clearances' closely.
If installing lower vent bottom of it should be flush with floor. (Don't need that floor vent)
Then install a upper vent in side wall (just like lower one)
Bottom of top vent should be level with top of fridge.
There should NOT be any clearance between top of fridge and cabinet....Zero clearance otherwise you create a dead air space
HERE is some Ventilation Installation information.
Proper clearances -------better cooling
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
