nineoaks2004
May 21, 2015Explorer
jrnymn7 wrote:
Venting from the side wall would work fine... mine does, and so do hundreds of thousands of other rv's. And you could, theoretically, end up drawing trapped exhaust pipe heated air up thru the cabinet.
But yes, the fuel filler is a logistics/safety issue, for sure. Any way you can install the fridge away from that area?
Most Pop Ups vent out the side and mine looks almost like yours, I hook up two 110 v fans that I took out of Traffic signal Cabinets and installed a switch to turn them on,they run when the fridge is on in warmer weather and I have the option to turn them on in cooler weather when I notice the temp climbing in the reefer. Your design seems to look good and should work well
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
