evy's avatar
evy
DIY 3 way refrigerator venting (drawing)
I'm working on my DIY conversion build out of a 2010 Ford extended E250.
I've red a lot of articles here and there about 3 way refrigerator venting, now I can't do the big two gravity vents/access door like they normally do.
But Here's another way that should provide even more air movement behind the fridge.
Using three 80mm PC fans (120cfm/0.54amps total), plugged to the fridge (I don't know how yet but I know there's a circuit especially for that) every time the fridge turns on the fans are activated.
I have never done this before, please tell me if you see anything wrong with this concept, thanks!
  • Why not make that 12" x 12" access door a vent, instead? These work well, and are screened:
    soffit vent
    They come in aluminum, white and brown.
    You could even hinge it on the bottom, and have 4 screws along the top. And put some 1/8" x 1/2" foam gasket in behind to keep the rain out.
    I have several of these on my minibus conversion. I cut them to size... one, two, or three sections.
    Two of those fans should be plenty... and only required during hot weather.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 31, 2025
