ktmrfs
Nov 07, 2022Explorer III
enblethen wrote:
The lite wire becomes a fuse if you use the 50 ampere's circuit. Failure in the heater could cause wire to melt down and create a fire situation.
EXACTLY!!! whole point is to make sure the wiring downstream of the breaker can handle the max breaker current in the case of a downstream fault. !!!!!
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
