Cummins12V98
Nov 11, 2022Explorer III
KnowNuthin wrote:Cummins12V98 wrote:
I advise 12GA wire and 20A breaker.
Our barn sub-panel is supplied by a 50@ 2-pole breaker in our main house panel… the circuits original purpose was to have a 240v, 50@ welder outlet in the garage.. I had an electrician repurpose that service to our 50@ RV plug in the barn (no longer a 240v outlet in the garage)…
I currently have one 50@ and 2-20@ breakers in the sub-panel… when we plug in the RV we shut off the. 20a breakers and vice-versa…
The spousal unit is an electrical engineer and as such has assured me EVERYTHING electrical is underrated… I.e. we have more than 50@ going into the barn panel and each of the breakers will handle more than their rated capacity (but will trip in the event of an short/overload)… at least that’s what I heard… when she gets going I understand about every third word, the rest is electrical-eze…
Chances are very good I won’t ever run each of the circuits up to their rated capacity… but I’m the worrying kind…
My intention was to replace one of the existing 20a breakers with a 15a then add a second 15a breaker…. Which would give me 20a + 15a + 15a = 50a (plus the dedicated 50a RV outlet)
Yes? No? Other suggestions?
You actually have two 50A circuits available as 100A total capacity. Add another 20A and forget it.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
