- ktmrfsExplorer IIIand if your going to use cable larger than about 10ga (small wire number) look into a good hydraulic crimper, avaiable on ebay at reasonable prices. especially once you get to cable sizes from 4ga down to #0000.
crimp, cover with adhesive lined heat shrink. All of mine I used welding cable I cut to length, again cable cutters avaiable on amazon or ebay. Since welding cable is usually only available in black, I use red or black heat shrink as appropriate. - mcheroExplorerThanks for the suggestions people!
- I get materials and use their tools at West Marine Supply.
- RoyBExplorer III ordered my new battery bank cables with ring terminal ends from AMAZON...
Roy Ken
- MEXICOWANDERERExplorerLugs are sized for SAE wire. Buy one gauge larger lugs for AWG cable
- MEXICOWANDERERExplorerDelcity.net
Quickcable.com - navigator2346ExplorerThis is the best place for what you need. Parts and custom cables are their specialty plus prices are reasonable.
http://www.genuinedealz.com/about/ - Home_SkilletExplorer IIMost auto parts stores would have what you need.
Or, welding supply stores.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
