pianotuna
Feb 13, 2016Nomad III
evy what is needed is a way to recharge the battery bank quickly and efficiently.
Best:
solar with a 3 or 4 stage controller
Why is it best? One time cost and nearly zero maintenance.
Good:
3 or 4 stage converter (or battery charger) that has at least enough amps to do C/5 (C = capacity of the battery bank in amp-hours at the 20 hour rate).
Ugly:
Any converter that puts out just one voltage.
If I were starting from scratch as you are, I'd look at a battery bank of at least 400 amp-hours. I'd add 600 watts of solar, with a top of the line controller. For extended poor solar days I'd have a smallish 40 amp converter.
I would rough in duct work for a future air conditioner. RV's are hot as Hades.
I would maximize insulation and use metal studs.
I would have at least two vents (three would be even better as when you add air you will loose one). I would put fantastic fans in two of the vents.
Best:
Good:
Ugly:
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
