Almot
Feb 14, 2016Explorer III
beemerphile1 wrote:
No reason to have a converter if you are almost exclusively boondocking.
Spend the money on a top quality battery charger instead, or better yet, a solar system.
Converter will work as a charger with generator.
Solar is better, it's a good charging source in addition to converter, and with enough solar wattage it can become the main source.
Battery bank is one of crucial points, for both solar and high-current loads like MW. The problem is - good suggestions don't seem to register even after repeated a few times. This indicates lack of understanding.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
