chilly81's avatar
chilly81
DIY suspension upgrade tips for full timer
Need to fix/upgrade my Nash 22H (dual 3500# dexter) suspension - new bushings, equalizer, shackles etc. Want to put in the dexter wet kit - minimal parts cost (~$150) vs. $650 or so for a dealer install.
I'm a full timer though and don't have compressors, garage. I'm technically competent, a couple jack stands, jack and standard tools (not bearing presses, gear pullers, impact guns etc). Also would be tough for me to get all 4 wheels in the air at a time - one side at a time would be preferable.
Just looking for tips or advice from those who have done it - from the perspective of being a full timer in a parking lot somewhere without a shop full of heavy tools.
  • brulaz wrote:
    B.O. Plenty wrote:
    Seems to me there used to be a sticky regarding this somewhere on here...
    B.O.
    That would be over in the Travel Trailer section at the top.
    Many pages of info and photos.
    That's a heck of a writeup - thanks!
    B.O.
  • Seems to me there used to be a sticky regarding this somewhere on here...
    B.O.
  • Mine went in fine with basic tools (no press).
    Although I did get four 12-ton jack stands to put the whole trailer up. One side at a time is plenty for one day.
    Consider new springs with higher rating at the same time.
  • I did mine one side at a time. I used 2 six ton jack stands and a six ton jack. A few wrenches, big hammer and something to protect the bolt head while pounding them in place.
  • A ball joint press makes it a lot easier.
    Also, consider the Lippert Neverfail bushings. No greasing and I have heard good reports. Minehave only been on a couple of years, but that is a LOT of miles with my usage.
    Lippert also makes a shock absorbing Equalizer. It works very well. I would choose that item based price.
    chilly81 wrote:
    MEXICOWANDERER wrote:
    You just may be able to source rental tools for your project. I sure would give that avenue a thorough look :)
    That's a good idea. Do you have any idea what tools specifically might be needed beyond the basics I have?
  • You just may be able to source rental tools for your project. I sure would give that avenue a thorough look :)
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
