noteven wrote:
If you look at the manual for a PD converter charger it should have graphs showing charging profiles. They will answer your specific questions if you call them.
I thought they detect the battery type automatically...
You can be severely misled by that manual. It does not discuss charging rates, and the PD requires that you keep hitting the boost button to keep it at 14.4v until battery acceptance is down to 0.5a per 100AH with AGMs, if it does drop to 13.6v on you before you get that far.
EDIT: PD says:
"The chart above shows the amount of time it took a PD9155 (55-amp) converter set to three different output voltages to recharge a 125 AH (Amp Hour) battery after it was fully discharged to 10.5-volts.
14.4-VOLTS (Boost Mode) – Returned the battery to 90% of full charge in approximately 3-hours. The battery reached full charge in approximately 11 hours"
So they used a 55 amper on a 125AH which is a 44% charging rate! Took 3 hours to 90% SOC.
And they started from 10.5 volts --which is a "dead" battery! My goodness. So it would maybe stay constant 55 to 60% SOC which is one hour, and now to do the 60-90 (37.5AH) with tapering amps from 55, which they say took another two hours.
So what good is that to know?
