I've come to the opinion that battery manufacurer recommendations as to voltage and charge rates are generalities mostly designed to bolster the bottom line of those companies by minimizing potential warranty returns.
This of course is largely a guess as to how the battery is going to be used and recharged by the end user, and if they think 16.2v EQ is going to reduce returns by 0.03% over 15.5v, then 16.2v it is.
Personal Experience with My TPPL Northstar AGM says feed the SOB with high amperage regularly, and do not go too many deep cycles with low and slow solar as the only recharging source.  If the voltage when cranking my engine is lower than desired, or overnight voltage is less than expected, then it is time to depleted it to 50% or Lower and stuff its 90Ah capacity with no less than 40 amps.
I would never recommend an AGM for those only capable of low and slow solar only recharges, or those who think their 2/12 amp garage charge is 'just fine'  after they drain it dead as a doornail.
I've some experience with New AGM batteries, but only when they were new, A Crown31 that had NO CCA figure, whose voltage under light loads was unimpressive, and a new Lifeline GPL-31XT whose voltage retention under discharge and charge acceptance rate, and full charge resting voltage were Very impressive.
I cannot speak to each and every other AGM battery, I think anybody who does is to be ignored. I have figured out what my battrey needs to perform well, and it is now over 5 years old, over 1000 deep cycles, and if it failed tomorrow I would Buy another Northstar AGM, as I love that my alternator can feed it when it is well depleted safely, 106 amps, and it has delivered ,ore KWH per $ than any other battery I have ever used, ut I can also rechrge it battery than any other battery I have cycled to death
Can another group 27 other than Lifeline or Odyssey( who makes no 27) accept 106 amps? Perhaps, but for how long before max voltage is reached and amps taper?
NOrthstar and Odyssey AGM have less resistance by ~25% for the same size battery as Lifeline and ridiculously high CCA and PCA figures, at least when new.
How long my AGM takes when depleted to reach absorption voltge at 40 or 65 amps is a ruler as to its health. and this high amp recharge until amps taper to 0.5% seems like a restorative charge.
Voltage retention under load, is a ruler
How long it takes amps to taper to 0.5% of capacity regardless of initial amperage or state of charge, is a ruler, but apples to apples is preferred.
Without actually having another battery to compare these expected times/numbers too, I can;t say whether the Lifeline is better, or the Full river is just as good, or the Asian UPGs can easily accept just as high amperage safely.  Experiment, measure their temperature, but blindly adhering to a max recommended charge rate, Never! not for me anyway.
Without data, its all just an opinion, and some data points I see written on forums, I just do not trust, and can't, unless I collect/witness it myself, as the human ego will dictate what the fingers type, and that could easily defy physics.
