- pianotunaNomad IIIHi Mex,
Thanks for two more wisdom gems. - MEXICOWANDERERExplorerBTW when the Peukert Factor becomes an issue, that's the limit for normal economic discharge in amps.
- MEXICOWANDERERExplorerAblative shedding PT :)
A 5-amp battery maintainer would allow safe storage when the battery is at 95%. Don't play games trying to store a battery with <85% full. You will lose. I do realize tenders of 5 amps are not common but try for the highest potential.
This is where you see the value of a Meanwell or Megawatt. Mere TOP CHARGING eliminates the need for equalizing up to 95%. Set for 15 volts. When 15 volts is reached a vague timer can be used to charge one hour per battery additional then shut off. VAGUE is just that. 15 volts. If curious do look at the cells. When they bubble you're done.
Triple-digit IQ allows a user to incorporate a wristwatch to TIME the top charge and then incorporate the elapsed time from then-on instead of using visual bubbling.
But then you can forget all this and just buy batteries twice as often.
EVERYTHING above is for flooded batteries.
And is calculated from 30 years of experimentation and verification by autopsy. - Sam_SpadeExplorer
pianotuna wrote:
Each and every time the batteries are cycled there is positive plate shaling. There is no way to reverse that.
GASP. :E
How dare you tell the truth about how wet cell batteries actually work.
:B - Sam_SpadeExplorer
BFL13 wrote:
If in "storage", the guides say to do a deep cycle every month or whenever.
What "guides" exactly ?
And we are talking about conventional lead acid batteries....right ??
I have NEVER seen a recommendation from a battery design engineer or from a company that makes batteries that said constant float at the proper voltage is NOT the best thing to do.
If there really is a recommendation contrary to that.....from a real authoritative source, that does not sell fancy chargers, I really would like to see it. - pianotunaNomad IIIwopachop,
Self discharge in an old aged battery may be 30% per month (less at cold temperatures, more at high temperatures). For a brand spanking new unit that may only be 5%.
Each and every time the batteries are cycled there is positive plate shaling. There is no way to reverse that. - BFL13Explorer II
wopachop wrote:
Let me please back up and make this more of a general question. Ignoring factors like ambient temps and abuse.
Do golf cart batteries like to be exercised with normal cycling?
Or would they last longer sitting on a shelf and getting charged when they reach 70 percent?
They will last longer doing shallow cycles than if doing deep cycles. If in "storage", the guides say to do a deep cycle every month or whenever. The frequency of this occasional deep cycle depends on the ambient temp. More often in hot temps, less often in cold temps.
There is a school that says 6v GCs should not be floated so much. Just disconnect once full and let them self-discharge to about 75% then recharge them to full again. I don't know if that is better. Xantrex Truecharge chargers had the option to shut off the third, Float stage, for that reason. - Sam_SpadeExplorer
In general, they last longer if they are KEPT fully charged when not being actively used.
That is what a smart automatic battery tender is for. - Sam_SpadeExplorer
wopachop wrote:
I'm manually discharging in the garage
Why ?
Conventional wet cell batteries do NOT benefit from "manual discharging". - wopachopExplorerLet me please back up and make this more of a general question. Ignoring factors like ambient temps and abuse.
