DSchmidt_2000
May 27, 2023Explorer
Here's an update - profile on charger set to use only 4A for the last stage of the charge (stage 3). I downloaded the charge history and see that the battery is hitting 63V at the end of the charge. Battery tops are staying dry so the designed overcharge isn't boiling away the electrolyte too much.
I'll keep monitoring the charge. (I really like that the charge logs each of the charges, including the voltage and time spend in each of the 3 charge stages.)
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
