DSchmidt_2000's avatar
May 09, 2023
Do golf cart chargers always charge to equalize voltage?
I'm asking you all because:
- you're all smart and have long term history with FLA batteries
- BuggiesGoneWild won't activate my acct for me to post my question there.
48V cart with new set of 6 qty 8V Trojan T-875 batteries and a Lester Summit II charger.
I'm helping someone with a golf cart at a horse ranch. Replaced bad batteries and dead charger. I topped each up individually before installing in the cart.
With the new batteries installed, I plugged the charger in expecting it to say "Fully Charged", but instead it started a charge cycle. After about 10-15 mins, the battery pack voltage went to 64.4V, 6.4A charge rate, cells were vigorously bubbling, a slight smell of rotten egg, and charger said estimate time to completion was 3 hours. I terminated the charge as it seemed excessive. Restarting it only did the same thing. Battery profile is correct for these batteries.
I called Lester the next day and was told this is normal. Part of their answer was that it will do an equalize charge every ~ 30 charges, but he also said it will go up to 64-65V with every single charge! They said it's normal, that Trojan gave them the charging profile to follow. They also said the charger is in phase 3, the finishing stage.
Trojan's datasheet shows a bulk charge voltage of 9.88V, equalize of 10.80. 6 x 10.80 = 64.8V. Datasheet
Question for you guys that either have a golf cart, with or without a Lester Summit II charger, do you view going to equalize voltage with every charge excessive? I don't want to cook these batteries, and I also don't want a coating of acid on everything.
I asked Trojan what they thought, and got short reply "the info you need is on our website".
I could load an AGM profile into the charger. This would take the batteries to 9.88V/battery, no equalize. Figure I could do a manual equalize once a month.
Thoughts?
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
