Homey_B's avatar
Homey_B
Do I have to worry about boiling my battery to death?
We're new-ish to the RV scene, and for our first year, DW and I have a seasonal campsite. It gives us the ability to enjoy weekends as well as to travel without having to deal with NYC/Long Island traffic.
As such, we're plugged into 30-amp juice 24x7. We have a WF-8955 power distribution center. No additional (yet) mods to the electrical system.
I've read posts where people say that leaving a battery connected full time is not a great idea, especially with factory power converter/chargers. We don't have a battery cut-off switch, so we're technically charging all the time.
Is this a recipe for disaster, at least as far as battery life goes? Will a cut-off make things better? Should I find some other charging unit just to keep the battery from cooking?
Any help is always greatly appreciated!
  • RoyB's avatar
    RoyB
    Explorer II
    I have a homemade installed battery bank monitor that is installed right next to my entrance door on my OFF-ROAD POPUP using SURE ELECTRONICS meters from ebay/china. I can get a quick check on the Dc voltage real easy having this meter panel here. Just a quick glance everytime I am around the trailer.
    I originally had an converter that only had a single mode charger in it which constantly put out 13.6VDC. This got me in the habit of checking battery fluids every couple of weeks and sooner. Since 2008 before I was watching things very close I did lose a battery from boiling out fluids. Now I am using either a WF8945 or a PD9260C smart mode converter but still out habit always keep watching the DC Voltage level and occasionally checking the battery fluids.. I am plugged into my garage 120VAC circuit 24/7 here when not on the road anywhere.
    Its just a good idea now for me to always be conscious of what is going on battery wise... I also can switch out my batteries but usually leave them all connected to the converters.
    Roy Ken
  • You'd need to check the water level at least once a month for sure.
    I killed a battery this way. Took a couple years, but on a trip we stopped one night in a state park with no hookups and discovered that the battery, while showing a full charge, was actually incapable of delivering more than about 30 seconds of light on one fixture/two bulbs inside the trailer. The battery had sulfated, and while showing full voltage, was none the less dead as a door nail.
    I installed a cut-off on the battery, and now leave the trailer off shore power, the battery disconnected, but on a Battery Minder, which is supposed to prevent sulfation while keeping the battery fully charged.
  • WFCO should drop voltage in after several days of minimal use to about 13.2 volts. If this actually happens consistantly then you are good to go. If it holds 13.6 you are ok but need to watch water level a bit more in hot weather. If it gets stuck in boost mode (14.4 volts) for more than six hours then you need to disconnect and replace the converter. (Mine did this)
  • Mine has been plugged in 24/7 last couple of years. I do check water level once a month. No problems yet.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
